XADC temperature alarms, hysteresis?
Hi all!
We are starting to use the XADC in our Zynq (XC7Z020) and the SW guys want to know if there is some hysteresis in the temperature alarm interrupts? There are two bits in particular that seems useful, bit 0 (OT) of cource and bit 8 (OT Deactive). If the temperature fluctuates around the limit (125 °C) these could easily generate bursts of interrups, so I assume there must be some sort of hysteresis, but I have not been able to find any such information in either the data sheet (DS187), the XADC User guide (UG480) or the LogiCORE IP AXI XADC product guide (PG019).
This question would apply to the supply sensor alarms as well.
Anyone with a clue?
/Lars
Re: XADC temperature alarms, hysteresis?
Thank you all for the input!
I gather that there is no hysteresis, but that if I enable averaging the low-pass effect of that will take care of any flipping around the threshold. That should be fine, considering that thermal effect should be quite slow in comparison.
/Lars
Scholar austin
l,
http://www.xilinx.com/products/intellectual-property/System_Monitor_Wizard.htm
Yes, the system monitor has various settings.  In the past (V5, V6) the users guides detailed the settings.  Now there is the above wizard to assist you.
and
http://www.xilinx.com/products/technology/analog-mixed-signal/index.htm
Austin Lesea
Principal Engineer
Xilinx San Jose
Use the average function. Take perhaps 256 samples (or some other average) before ringing the alarm.
Scholar markcurry
Be careful, and analyze your application.  A generic "average 256 samples" may sound like an appropriate filter, but this adds 128 samples of latency to your measurements.  Is this ok?
This kind of falls under a similar quote from Knuth:
"Random numbers should not be generated with a method chosen at random"'.
A similar quote should be crafted for digital filters.
Mark
Averaging is perfectly fine for this. That's why it's there. The key is that the part will not instantly "heat up" if current goes up. For sake of argument, if you take the current from 0 to 50A in an instant then that does not mean Tj will instantly go to 125C (or whatever). Depending on environment (air, heat sink, etc.) and package you may experience an increase in Tj of about 8 - 10C per sec. So the sampling is plenty fast for that. The idea is to filter out the noise factor. Even if latency was an issue, which it isn't, you could set your alarm right below the threshold.
/Lars
Scholar austin
l,
You can place your own hysterisis in software.  If the threshold is reached in 256 samples (or 2048, etc.), set a flag to overtemp=true.  If overtemp=true is set, then subsequent interrupts check the value.  If the value falls below a windowed value, reset the flag, else do nothing (return).
Austin Lesea
Principal Engineer
Xilinx San Jose
Hi Lars,
There actually is 'hysteresis' on the OT - the defaul OT  power-down temp is 125C, and the default OT power-up temp is 70C - so OT is set when temperature is > 125C, and it stays set until the temperature falls back below 70C.
Both thresholds are programmable.
Hope this helps,
John
