ZYNQ differential clock input
I have an AFE interfaced to a ZYNQ 007S.  The output of the AFE has LVDS clock and data.
My question:
Can I use the following for the clock and data in the FPGA?
//  clock
    IBUFDS #
        .DIFF_TERM      ( "FALSE"   ),      // Differential Termination
        .IBUF_LOW_PWR   ( "FALSE"    ),      // Low power="TRUE", Highest performance="FALSE"
        .IOSTANDARD     ( "LVDS_25" )       // Specify the input I/O standard
    IBUFDS_clock
        .O              ( rxclk_out ),      // Buffer output
        .I              ( clkin1_p  ),      // Diff_p buffer input (connect directly to top-level port)
        .IB             ( clkin1_n  )       // Diff_n buffer input (connect directly to top-level port)
//  Data input 0
    IBUFDS #
    IBUFDS_D0
        .O              ( din_0     ),      // Buffer output
        .I              ( din_p[0]  ),      // Diff_p buffer input (connect directly to top-level port)
        .IB             ( din_n[0]  )       // Diff_n buffer input (connect directly to top-level port)
Dan
Re: ZYNQ differential clock input
yes this will work fine.
You just need to be careful that you lock the clock to a Clock Capable input.
You can check the Clocking UG for more
Keith
Hi Keith,
Thanks for the reply.  I've since learned that I need to use both edges of the clock to clock the data into the FPGA.  I tried an always @ (posedge clk or negedge clk), but it wouldn't synthesize.  Any suggestions?
Dan
You need to use an IDDR in this case.
Hi Keith,
I looked at the macro for the IDDR.  It looks like it uses the p/n clock and will give me a 2-bit parallel output.  However, I'm not sure how to clock those bits into a shift register.  Would I still use the IBUFDS to recover the clock for internal use and do something like this:
sreg <= {Q0,Q1,sreg[6:1]};
Dan
