Visitor sigua1987
which is correct?
Re: which is correct?
Hi @sigua1987
It looks like you are using zynq 7z030sbg485 device, for this device the correct package numbers are listed in left CSV file. For package placement diagram, refer to page-633 figure 21-3 in this UG  https://www.xilinx.com/support/documentation/user_guides/ug585-Zynq-7000-TRM.pdf
Deepika.
Hi @sigua1987
Which device are you using? Which document you are comparing against the user guide?
Thanks,Vijay
Hi @sigua1987
Deepika.
