xapp524 16-bit 1-wire simulation
I am trying to simulate the xapp524 with 16-bit 1-wire configuration.
constant Sim_C_AdcWireInt : integer := 1; -- 1-wire
constant Sim_C_FrmPattern : string := "1111111100000000"; -- 1-wire pattern.
The default configuration simulates without an issue.
But with the above configuration, it never becomes stable. I have attached a screenshot of the simulation
After staying in FE01, it keeps toggling between FEFF and FE00.
I saw that there are 2 posts with the same issue. But there had not been a solution suggested.
Tags (3)
Re: xapp524 16-bit 1-wire simulation
I am familiar with this XAPP but I have not simulated extensively.
can you explain what you mean when you say the default configuration works?
What set up is this?
