Visitor suisui0207
2000t axi memory mapped to pcie IP issue
I generated one axi memory mapped to pcie IP, and open example design,I found s_* ports are not used for this example,so I connect a AXI master model to s_* for Upstream requeset. When simulate one issue occur:Upstream read requeset get a S_AXI_RRESP=2'b10 status. From wave file I found “/board/XILINX_AXIPCIE_EP/axi_pcie_0_i/inst/comp_axi_enhanced_pcie/m_axis_rc_tdata[127:0]=128'b 7417d986 01a00000 00002004 0a000000" the completion is Unsupported Request (UR).Why have this issue? Please help me solve the issue. Thank you!
Re: 2000t axi memory mapped to pcie IP issue
What kind of request did you make? Can you let me know the content of the request and also IP version because I will try to reproduce it?
Visitor suisui0207
IP version="2.9",requeset is Memory read,all memory read is the same situation
The root port model generated with this IP does not return a completion to a Memory Read request from EP. TSK_TX_CoMPLETION_DATA can be used when you modify the RP code in order to return a completion.
The following is just a simple example  :
<< pci_exp_usrapp_com.v >>
// Add the following in TSK_3DW
 reg [7:0]  B1;
 reg [15:0] B23;
 reg [2:0] tc_;
 reg [9:0] len_;
 reg [11:0] byte_count_;
 reg [6:0] lower_addr_;
 reg [2:0] comp_status_;
 reg ep_;
begin
// Omitted
    `PCI_EXP_MEM_READ32: begin
     if ( txrx == 0) begin
          // For Completion
      B1  =  frame_store_rx[1];
      B23 = {frame_store_rx[2], frame_store_rx[3]};
      tc_   = B1[6:4];
      len_ = B23[9:0];
      byte_count_  = (len_ * 4);
      lower_addr_  = 7'h00;
      comp_status_ = 3'b000;
      ep_           = 1'b0;
      requester_id =  {frame_store_rx[4], frame_store_rx[5]};
      tag =  frame_store_rx[6];
      board.RP.tx_usrapp.TSK_TX_COMPLETION_DATA(tag, tc_, len_, byte_count_, lower_addr_, comp_status_, ep_);
      end
    end
