DMA for PCI Express AER Support (Gen2 PCIe / Kintex 7)
Accepted Solution Solved
Accepted Solution
Does the DMA for PCI Express IP support PCIe Advanced Error Reporting (AER) for PCIe Gen 2 designs?
According to PG195, v3.1, pg 8, it indicates "AER (only PCIe 3.x core)". Does this mean a PCIe Gen 3 core? Or version 3.x of the Integrated Block for PCI Express?
I am assuming it means a PCIe Gen3 core. If this is the case it must be a design decision to not implement AER in the DMA IP since the 7 series Integrated Block for PCI Express does support AER.
Re: DMA for PCI Express AER Support (Gen2 PCIe / Kintex 7)
Yes this indicated the Gen3 IP and it is not supported for Gen2 and is supported only for Gen3.
I have done some testing locally with a KC705 when I opened the configuration wizard for that IP, I see AER is not enabled. If I do the same for VC709, I see AER enabled. So the PG is correct.
Kind regards,
Gareth
Kind regards,
Gareth
All Replies
Kind regards,
Gareth
Kind regards,
Gareth
