Generating MSI interrupts
In my design I'm using the PCIe DMA Subsystem:
https://www.xilinx.com/support/documentation/ip_documentation/xdma/v4_1/pg195-pcie-dma.pdf
Page 117 shows that 4 different types of interrupt mechanisms are supported.
Question:
Suppose I want the FPGA logic to invoke an MSI or an MSI-X interrupt at the host.
What's the correct process for that ?
回复: Generating MSI interrupts
yes if both 1 and 2 are correctly finished
that means the MSI func is enabled and not masked,the bus master bit is on and  the vector is set correctly
1The host will need to first config the MSI /MSIX registers in the config space.
For MSIX , the MSIX table will be filled out by the host too
2 driver needs to config the DMA IRQ  registers in  Table 2-77: IRQ Block Register Space
3 channel or user interrupt be triggered by DMA engine or user
So if the user fpga application raises one of the bits of the usr_irq_req vector - this will raise an MSI interrupt ?
