Observer dorbd
PCIe device cannot start (code 10)
Hello everyone,
I am working on windows 7- 64bit,, and trying to work with the PCIe on VC709 board.
  • I programmed the device with the tutorial (AXI PCI Express MIG Subsystem built in IPI).
  • But when i install the driver (from answer 65444),  it says the "This device cannot start. (Code 10)", how do i solve this?
  • moreover, how do i test the transaction from the PC to the PCIe?
thanks.
Re: PCIe device cannot start (code 10)
@dorbd
I hope you are referring to the video tutorial at the link - https://www.xilinx.com/video/fpga/axi-pci-express-mig-subsystem-built-in-ipi.html
I find the driver mentioned in the video is from xapp1022 - https://www.xilinx.com/support/documentation/application_notes/xapp1022.pdf
Can you try using this driver?
Observer dorbd
Thanks for ur answer,
this MET Driver does not work with 64bit, if there is any other driver i can try.
and yes, this is the tutorial im reffering to.
@dorbd
MET driver with xapp1022 is validated on Windows XP.
Can you try the Linux driver on a Linux machine?
