Newbie deltagods
Using microblaze with the 7 series integrated block pcie
Is it possible to the use the microblaze ip core to write c code and have it work with the 7 series integrated block pcie to send and recieve TLPs?
https://www.xilinx.com/products/intellectual-property/7_series_pci_express_block.html
I wish to send and receive TLPs using c code on the Artix 7 fpga. Particularly send DMA requests to the host system and send and receive commands from the host's memory (or rather a windows process on the host system)
Re: Using microblaze with the 7 series integrated block pcie
If you are using a Microblaze, I would recommend looking instead at the AXI Memory Mapped for PCI Express IP.  The 7-series Integrated block requires user logic to form the TLPs to be sent and is AXI-Stream.  The AXI Memory Mapped for PCI Express IP is AXI-4 and hooks into a microblaze quite a bit more easily.
