AR65444 Driver Version: 0.45 Small Issue
I appreciate this driver. I was looking through the code and there seems to be a small issue.
xdma-core.c Line 3927
This block of code is repeated twice:
        /* fetch device specific data stored earlier during open */
        lro_char = (struct xdma_char *)file->private_data;
        BUG_ON(!lro_char);
        BUG_ON(lro_char->magic != MAGIC_CHAR);
        lro = lro_char->lro;
        BUG_ON(!lro);
        BUG_ON(lro->magic != MAGIC_DEVICE);
        engine = lro_char->engine;
Dave
Thanks for reporting this. We will review and fix the code as required.
@venkata @cospandesign
Is it safe to comment out the repeated version of the block ?
@venkata
The reason I asked is that, I am unable to use the new version of the driver Xilinx_Answer_65444_Linux_Files_rel20180420.zip because I noticed in dmesg log that xdma_isr() is continuously being executed even though FPGA logic is not generating that interrupt. I pointed out this error in https://forums.xilinx.com/t5/PCI-Express/no-C2H-channels-enabled-AR65444/m-p/855547#M10854
Commenting out that portion of the code will have no effect on your issue. That part of the code just assigned three values to thee locations and then assigned those three values again.
Structurally it didn't change anything.
