AXI Memory mapped to PCIe - WRAP burst / Cacheable transactions
Hello Everyone,
In the IP core datasheet it is mentioned that only INCR burst type access is supported.
This is a blocker for my design. I am wondering if a workaround or patch is available from Xilinx to support WRAP burst transactions.
Also curious to know if the memory supports Cacheable transactions.
Please let me know if an alternative to this bridge is available which supports WRAP burst and Cacheable memory transactions.
garethc
HI @Arpitrathi31260
Can you take a look at our PCIe and CPM board - Useful Resources sticky post from the link below.
https://forums.xilinx.com/t5/PCIe-and-CPM/PCIE-and-CPM-Useful-Resources/td-p/1079558
This details all our PCIe IPs including our bridge IPs and you can review them but to my knowledge we only support INCR burst type.
Gareth
Versal Blogs
