wyldecat
Any partial reconfiguration example with VCU1525 board?
I'm trying to do partial reconfiguration with VCU1525 board by reference to this document (https://www.xilinx.com/support/documentation/application_notes/xapp1338-fast-partial-reconfiguration-pci-express.pdf).
But my system crashes when I send partial binary file via DMA.
Does anyone have a working example?
garethc
Hi @wyldecat
I was doing a sweep of Forum Posts and I seen this, this may not be an issue for you anymore but I thought I would reply to check. I do not believe we have an example other than what is detailed in the XAPP you mentioned.For Tandem with Field Updates we seen some second stage issues and these are resolved with AR:71877. I know you are not using Tandem WFU but this may help as Tandem WFU is like a PR flow.
https://www.xilinx.com/support/answers/71877.html
Gareth
Versal Blogs
