Artix-7 PCIe endpoint without DDR
Is there a good reference design or development board for a PCIe endpoint without DDR3 memory or the MIG?  I need a Linux CPU to move short (4K) packets back and forth with a microblaze.
the XDMA example design with a RAM could be used as EP
the microblaze is not needed by default
