Axi Bridge: Throughput reduction
for the recent project, I have to analyse a system, which uses the PCI-Express Axi Bridge (axi_pcie 1.02.a). Due to my simulation results (see attachment), I saw that I lose nearly half of the performance of PCIe throughput with 4 lanes.
I discovered in the vhd-file axi_slave_write.vhd (axi_pcie_mm_s_v1_02_a) that only one burst is executed at a time till it is sent to the PCIe hardmarco. Not till then, the next AXI burst can be executed.
Is there a special reason, why the transmission from AXI Memory Mapped to FIFO and FIFO to AXI-Stream is not pipelined?
It's always good practice giving feedback, when description/solution/recommendation have been helpful!
This is a known restriction in v1.02a
This is fixed in v1.03a, scheduled to come out in 14.1
Hope this helps.
Thanks for your reply,
I'll forward this info to my colleagues.
When can we expect the release of 14.1? Couple of months, half a year?
This could be a critical information how to proceed with our project.
14.1 is planned to be released in about a month (May timeline).
Chris
