min16
Bypass configuration messages at endpoint (PCIE40E4)
Hi, is there anyway to bypass configuration messages from the host to Ultrascale+ endpoint IP?
I need to build all pcie configuration spaces inside my user logic but I don't know how to let configuration messages from the host to be delivered through PCIE40E4 (PG213) IP from Xilinx.
Thank you in advance.
min16
Through some experiments, I actually found cfg_ext_* interface is outputing enough information for me even if the host is accessing configuration space not withtin 0x480-0x4ff. I'm just using this port for my purpose.
min16
