Can't select 5.0 GT/s with a width of x8 in the AXI Memory Mapped to PCI Express 2.8 on a xc7z045ffg900-2 in Vivado 2018.2
According to the following table, the XC7Z045 supports a PCIe configuration of Gen2 x8:
However, when configuring the AXI Memory Mapped to PCI Express 2.8 IP in Vivado 2018.2, I can only select either 2.5 GT/s x8. I can however select 5.0 GT/s x4.
Is this a bug in the configuration wizard, am I missing something, or does this FPGA not actually support this configuration?
Re: Can't select 5.0 GT/s with a width of x8 in the AXI Memory Mapped to PCI Express 2.8 on a xc7z045ffg900-2 in Vivado 2018.2
Hi @isaacjt
I can confirm that the AXI MM PCIe IP is showing correct behaviour and Gen2 x8 is not supported with this IP. Only up to Gen2 x4 is supported and for x8 Gen1 is required. Table 1 is correct below as this is a restriction in the AXI MM PCIe IP and our 7 Series Integrated PCIe Block IP supports Gen2 x8. I have filed a CR for our document to clarify this in PG055 as this is not clear with reference to Gen2 x8 in it.
Kind regards,
Gareth
Hi @isaacjt
Kind regards,
Gareth
