kapsy_27
Cant access internal registers of 32-bit Initiater/Target for PCI through pcitree
I am using 32-bit Initiater/Target for PCI in a spartan-3 device, and defined some internal registers which I want to write and read. I have defined BAR0 as I/O and address space of 128 bytes. and written the following code to access the registers:
elsif CLK'event and CLK = '1' then
case (ADDR(9 downto 2)) is
--- ADDRESS 0x00 FOR reg0
when x"00" => reg_hit <= reg0;
if bar_0_wr = '1' and S_DATA_VLD = '1' then
reg0 <= ADIO;
end if;
--- ADDRESS 0x04 FOR reg1----
when x"01" => reg_hit <= reg1;
reg1 <= ADIO;
end if;
--- ADDRESS 0x08 FOR reg2----
when x"02" => reg_hit <= reg2;
reg2 <= ADIO;
end if;
--- ADDRESS 0x0C FOR reg3---
when x"03" => reg_hit <= reg3;
reg3 <= ADIO;
end if;
When I program the FPGA and try to access these registers through pcitree, I am not able to access these registers. Do I require any driver to read/write the registers through pcitree. Following is the image read by the pcitree.
kapsy_27
Please can anyboady suggest me anything...!
vsrunga
What is your machine configuration?
Please go through FAQs and related discussions from below links and check if they give you any clues
http://www.pcitree.de/userguide.html#Concerns
http://forums.xilinx.com/t5/PCI-Express/PCI-tree-for-64-bit-machine/td-p/219183
Hope this helps
-Vanitha
kapsy_27
Mine is 32-bit-machine.
kapsy_27
I am able to access these registers when I define BAR0 in Memory space instead of I/O space. what might be the reason? is it because of the system does not have any I/O space left to accommodate my device thats why I am not able to access these registers, since I/O space is limited and fragmented.
kotir
Hi ,
I think if it is memory you can do posted writes of bigger size (multi DW).
For I/O you can do only 1 DW writes. May be the you have to do update for one location at a time.
Have you tried it ?
KR
