DMA/Bridge subsystem PCIe IP example design
Hi sir,
In example design i kept xilinx DMA/Bridge Subsystem IP at EP side and then RP model is generated in example design so at S_AXI_Lite and S_AXI_B side of EP ip i have connected Microblaze and then i am trying to read in simulation this 0x******00, 0x******10 and 0x******78 register through AXI_LITE interface to write C code for that. But I am not getting rready signal and rdata .
In example design we are writing from RP model to EP side BRAM and then reading back. Now i want to write from EP side through Microblaze interface to using AXI interface. You know through AXI_LITE we can read the configuration registers but i am not able to read it.
I tried to write 0xFFFFFFFF on 0x******10h register address and then reading it back. You know to write on BAR0 address FFFFFF we can read range of that address.But i am not getting any value even not getting rready signal high.
I am going to attach my design flow also
回复: DMA/Bridge subsystem PCIe IP example design
In order to read the RP , the bus master bit in the EP should be enabled
that is the bit2 of command register  (address 04)
Visitor rahul090192
Have to write at S_Axi_Lite  port na?²
sir 0x000-0x12F resgster offset are RO. PG194 page 33. so we can write on 0x04
I have tried to write 0xbase_addr+04 address by 0x00000002 value and then tried to read register from 0x00 to 0x21 but not getting anything ..using C code through microblaze at axi_lite port i am trying to read/write.
