chris-bu
Display goes blank during boot with SP605
I need a recommended PC for working with the SP605 evaluation board. I purcahsed a computer to work with this board, but during the boot process, before I see the windows log-in dialog, the computer display is disabled. I tried using two different display adapters with the same result. If you log-in remotely the display adapter will not even show up in device manager when the SP605 is installed.
The same SP605 board worked on two other computers, so I am not sure what the issue is.
Is there a recommended PC for working with this board?
pratham
AR# 18419 - Install - Operating System (OS) Support on Xilinx ISE Design Tools - http://www.xilinx.com/support/answers/18419.htm
These os are supported by Xilinx it doesn't varies from board to board
-Pratham
pratham
-Pratham
chris-bu
I am using Windows 7, 64-bit, which is supported.
Are you generally ok with any standard PC running a supported OS?
pratham
Yes as long as it follows memory recommendation given in the link
Design Tools : Memory Recommendations - http://www.xilinx.com/design-tools/vivado/memory.htm
-Pratham
chris-bu
Thank you. I guess that I have unfortunately found the only bad configuration, and I will just purcahse a standard Dell PC and work with that.
For anyone else: I don't recommend using an intel Z77 chipset, i7 processor and SP605 motherboard in combination. All other configurations seem to work.
I appreciate your help,
Chris
kotir
Hi Chi,
If the Mother board is compliant of PCIe spec then it should not be a problem with detection and working with SP605.
Check your mother board has any options where the slot on which you are connecting is dedicated for a Graphics card or some thing like that.
This could be a possible reason.
Koti reddy
chris-bu
Thank you for the recommendation. I have tried using the cards in different slots, and even swapping the two cards results in the same behavior.
I am going to give up on this PC, and use the card in a different computer. I do have a working configuration which is sufficient for me at this point.
Chris
