Anonymous
Not applicable
Driver source for Spartan 6?
In design when using Spartan 6 (like in the ML605 eval board) and connected directly to the PCIe slot in the PC motherboard, is there any device driver sample or demo from xilinx for the PCI express driver, access to read/write registers or for memory read/write.
I what to write my own windows application for the testing our design.
Anonymous
Not applicable
Anonymous
Not applicable
i need device driver code sample for the xilunx PCIe core for windows ...
any help... :smileyindifferent: ???
jayer
XAPP1052 includes source for the Windows driver and application. It might be of some use.
http://www.xilinx.com/support/documentation/application_notes/xapp1052.pdf
John
Anonymous
Not applicable
Thanks for the app note 1052, but i need help on writing driver using the SP605 using the
SP605 PCIe x1 Gen1 Design Creation from xlinx , if xlinx gave example for design of the PCIE solution why not supply simple driver with souce just to read registers/memory?
starting to write driver using the PLX KMDF sample driver code for the SP605 but still have alot to go. i could not read/write the memory from/to the SP605 each time the copmuter crushes, is it possible to get information on how to read/write the memory that is used the SP605 PCIe x1 Gen1 Design Creation (XTP605) i using the proms files from xlinx (what address/register could be used and sequence ...)
it sounds like really easy but i missing something ?!
stiegman
Did you ever get a response with regard to your saearch for driver source code?
