How to generate example designs for PG195
How can i generate the example designs mentioned in PG195?
I would like to use KC705 as a platform.
by default it will be  Memory Mapped Default Example
A different Example design will be generated based on  the Option you select in the GUI
For example,if you select Memory map or Memory stream interface . if you select DMA bypass interface or not.
a different example design will be generated
you can right click the xci choose open example design
the driver is available  in AR 65444
https://www.xilinx.com/support/answers/65444.html
Ok, thanks. In PG195 five different example designs are described. How can I choose which one gets generated?
