massi_jam
Modelsim (vish-4014) error with endpoint 1.9 design simulation
Hi everyone,
I'm running  the  endpoint 1.9 design simulation using modelsim SE 6.4, using VHDL. The simulation complete successfully, but when I try to open the resulting vsim.wlf file I get the following error message:
# (vish-4014) No objects found matching '*'.
Google says that it should be a bug related to the 6.2, 6.3 versions of modelsim.
It also suggests to set VoptFlow to 0 in the modelsim.ini file. I tried that but nothing changed...any ideas?
Thanks in advance.
grs
I generated a v1.9.4 PCIe x1 core in VHDL. I simulated with 6.4b. Simulation completed successfully. I then closed the simulation and opened vsim.wlf with no problem.
