sitting
PCI-E on MPSoC 6EG
Is it possible to implement pci-e soft ip on mpsoc 6eg?
Sitting
garethc
Hi @sitting
By PCIe soft IP I expect you mean the US+ Integrated Block for PCI Express as detailed on PG213 or the DMA/Bridge Subsystem for PCI Express (XDMA) as detailed in PG195?
If this is the case then you cannot use these with Zynq US+ MPSoC 6EG devices. If you look in the PG213 there is a table for available integrated blocks for PCI Express and there is no block listed for Zynq US+ MPSoC 6EG devices.
This is also confirmed in DS891, Zynq US+ MPSoC Data Sheet Overview document that lists the different devices and the feature summary tables for devices. Please see the table below and for 6EG devices there is no PCIe block.
Gareth
Versal Blogs
garethc
Hi @sitting
Gareth
Versal Blogs
