Participant deepwavebill
PCIe DMA test bench combined with JESD204B IP integrator core
I have a design where the two main components are the PCIe DMA core and the JESD204B core designed with IP integrator. In order to test the design I am trying to leverage the PCIe DMA test bench. I have only been able to successfully generate the PCIe DMA core example design in Vivado 2016.4. My problem is that I have designed the JESD204B IP integrator design in Vivado 2017.4 and it does not appear to be backward compatible to Vivado 2016.4. I also get a lot of errors when I try to convert the PCIe DMA core example design to Vivado 2017.4. Do you have any suggestions on how I can get both cores into a common design in some version of Vivado. Thanks.
Re: PCIe DMA test bench combined with JESD204B IP integrator core
This was my issue. Once I generated the core with Vivado 2017.4 I was able to generate an example design and the test bench for the PCIe DMA core and I am able to add the JESD204B block design. Thanks for your help.
Hi @deepwavebill,
A couple of items / questions:
For 2017.4, did you regenerate the IP, then regenerate the Example Design?   The example design code is locked to a specific version, it does not inherently regenerate if you upgrade the design.  I would recommend this path if it isn't what you are doing.
The 2017.4 version of XDMA example design should work fine, and had quite a bit of testing behind it.  If you try the above, and are still getting errors, can you please provide the XCI and errors you are getting?
