damon84
PCIe VHDL simulation with Active-HDL
I'm trying to get the Spartan 6 PCIe endpoint example simulated in Aldec Active-HDL (VHDL-only license), but I'm running into an issue with axi_basic_top - there seem to be only Verilog files for this portion of the project. Is it possible to simulate the Spartan 6 integrated block for PCIe within Aldec Active-HDL with only a VHDL simulation license? Thanks.
Damon
jayer
If you use ISE 13.2 and generate a v2.3 S6 core, you will get VHDL files for the AXI wrapper source.
It will have to be able to simulate the underlying SecureIP model which requires a Verilog LRM-IEEE 1364-2005 encryption-compliant simulator The SecureIP models the GTPs and the PCIe block. I am not familiar with how Aldec would handle this but for a simulator like MTI, there is a way to enable this functionality without getting a full Verilog license.
Hope this helps,
John
