Observer mozi87
Peer-to-peer transaction between physical functions
As I know, the Xilinx Integrated Block for PCI Express supports a multi-function device, up to two physical functions for UltraScale.
Is it possible to directly transfer data between the physical functions without redirecting to upstream such as switch or root complex (i.e., peer-to-peer transaction between physical functions within the endpoint device)?
Re: Peer-to-peer transaction between physical functions
- Do you mean that the Integrated Block is possible to transfer data from a function to other function (both in the same endpoint (i.e., FPGA)) with redirecting the transaction to switch or root complex?
Once the data traffic has come through the AXI-Stream interface, you could potentially route that data to the user logic managing that function.  It would not be PCIe transfers, it would be your user logic managing this - because even with multiple functions, the actual FPGA user logic interface is still a single interface.
- In that case, a FPGA will include both a switch and Integrated Block for PCI Express. Am I correct?
Please see above.  We do not currently have an IP internal to the FPGA that is a PCIe switch.  You would be doing the logical transfer interior to the FPGA, not using the PCIe side of the core.
- QDMA Mailboxes
QDMA does indeed have a mailbox mechanism inside the core that allows Mailbox transfers -- however these are not done via PCIe, they are done inside the logic in the FPGA.  This is not the same as PCIe peer-to-peer.
On the PCIe interface, internal peer-to-peer functionality is not available in the core.  However, with the Integrated Block, you could transfer back-end traffic or data in the user logic.  For true Peer-to-Peer, you would need a switch capable of this.
Observer mozi87
Thank you for reply.
- OK
By the way, I found that a QDMA supports a communication between physical or virtual functions as below:
'Any PF or VF can communicate to a PF (not itself) through mailbox.' (p.24 in PG302)
Is that not a peer-to-peer transaction but redirected transaction to root complex?
- QDMA Mailboxes
Observer mozi87
Thanks a lot for detailed explanation, bethe.
