yuryan16
Problem with B_GTXE2_CHANNEL when trying to simulate PCIe Core in VCS
I'm trying to simulate the PCIe core in a Virtex-7 with VCS in our SOC environment.
When I start the compile in VCS. I get this error
Error-[URMI] Unresolved modules
/home/cad/ise13.2/ISE_DS/ISE/verilog/src/unisims/GTXE2_CHANNEL.v, 2952
"B_GTXE2_CHANNEL_INST"
Module definition of above instance is not found in the design.
Please help to suggest which lib / files / path we need to include to fix this compile error.
Ryan
yenigal
Did you compile the simulation libraries for VCS.
Check UG900 for more details about compiling simulation libraries for third party simulators.
Satish
kotir
Hi ,
It looks like the libraries does not have GT secure premitive compiled in.
Try to compile below file also in the compilation script.
<ise insatllation >ISE_DS\ISE\secureip\vcs\gtxe2_channel_vcs\gtxe2_channel.vp
KR
smarell
Community Manager
Community Manager
B_GTXE2_CHANNEL_INST is an internal module and no source code is available for this primitive in the libraries.
If you have compiled the simulation libraries, that should take care of this.
Please re-compile the libraries and try it again.
What is the simulator version that you are using and which version of ISE or Vivado?
yuryan16
Thanks for helping
We added this file to compile, but it did not help.
We are using vcs1112sp1 with ISE13.2, is it too old ?
yenigal
After compiling the libraries and mapping the gtxe2_channel.vp do you still see the error on G​TXE2_CHANNEL or any other errors.
Can you attach the simulation log.
The compatible VCS version for ISE13.2 is VCS MX (2010.06)
Try with it and check if it resolves the issue.
Satish
