dsakjl
QDMA: bug in FLR configuration
Hi all,
we are using QDMA IP v3.0 (Rev 73653) on Vivado 2019.2,
and Xilinx driver (https://github.com/Xilinx/dma_ip_drivers/tree/master/QDMA/linux-kernel).
We enabled FLR and use the functions qdma_device_flr_quirk_set() and
qdma_device_flr_quirk_check().
We found that the invocation of qdma_device_flr_quirk_set() freezes the machine.
In particular, this happens when the function qdma_initiate_flr() tries to access
the register "FLR Control/Status Register" at offset 0x2500.
Investigating the problem we found that FLR needs the mailbox enabled.
So we would like to signal what seems a configuration's BUG.
Anyone from Xilinx can reply on this?
Thank you, best regards.
dsakjl
Hello everyone,
here is a patch for the QDMA 3.0 IP configuration. With this patch in place enabling FLR will imply the mailbox enabling.
The patch can be applied to the file Vivado/2019.2/data/ip/xilinx/qdma_v3_0/xgui/qdma_v3_0.tcl.
On linux:
$ cd /opt/xilinx/Vivado/2019.2/data/ip/xilinx/qdma_v3_0/xgui
$ patch -p0 < qdma_v3_0.tcl.patch
The patch is as simple as adding the following lines to the xgui tcl file:
proc update_PARAM_VALUE.MAILBOX_ENABLE {PARAM_VALUE.MAILBOX_ENABLE PARAM_VALUE.flr_enable} {
    set flr_enable [get_property value ${PARAM_VALUE.flr_enable}]
    if {$flr_enable == "true"} {
        set_property enabled true ${PARAM_VALUE.MAILBOX_ENABLE}
        set_property value true ${PARAM_VALUE.MAILBOX_ENABLE}
    } else {
        set_property value [get_property default_value ${PARAM_VALUE.MAILBOX_ENABLE}] ${PARAM_VALUE.MAILBOX_ENABLE}
Hope this would be helpful.
Regards.
dsakjl
Hello everyone,
On linux:
    } else {
Regards.
dsakjl
Hi @deepeshm ,
as requested I report this possible bug to you.
Best regards.
deepeshm
Thanks @dsakjl
We will investigate this and take needful actions.
Thank you for reporting the issue and providing the patch.
