QDMA example design on Alveo U50
I'm trying to get QDMA example working on the Alveo U50 using the Vivado flow with the IP integrator.
When trying to open the example design, I see the following errors in the console:
# generate_target open_example [get_ips qdma_1]
ERROR: [IP_Flow 19-3461] Value '4' is out of the range for parameter 'Pf0 Sriov Cap Initial Vf(PF1_SRIOV_CAP_INITIAL_VF)' for BD Cell 'qdma_1' . Valid values are - 0
ERROR: [IP_Flow 19-3461] Value '4' is out of the range for parameter 'Pf0 Sriov Cap Initial Vf(PF2_SRIOV_CAP_INITIAL_VF)' for BD Cell 'qdma_1' . Valid values are - 0
ERROR: [IP_Flow 19-3461] Value '4' is out of the range for parameter 'Pf3 Sriov Cap Initial Vf(PF3_SRIOV_CAP_INITIAL_VF)' for BD Cell 'qdma_1' . Valid values are - 0
INFO: [IP_Flow 19-3438] Customization errors found on 'qdma_1'. Restoring to previous valid configuration.
ERROR: [IP_Flow 19-98] Generation of the IP CORE failed.
Failed to customize IP 'qdma_1'. Failed to apply user parameter values.
INFO: [Common 17-206] Exiting Vivado at Fri Jul  3 22:30:41 2020...
ERROR: [Common 17-69] Command failed: Unable to open example project; see previous messages.
Can someone please advise how to fix this ? I am trying to get a single function device example design and don't need SR-IOV functionality so it is disabled.
Seems like the example design has a bug ?
Hi @mateuszberezecki ,
Can you share the .xci file of the QDMA IP?
Srinadh
Hi@venkata ,
I'm attaching the .xci file for the QDMA IP
I am experiencing the same problem. Can you share the solution if you found one?
I have managed to find a solution.
Previously, I tried to open the example design in a block design. In this case, I couldn't open the example design.
When I open the example design in the IP catalog section, it works.
