Question about Connecting Jetson AGX Xavier with VCU128 via PCIe
I have a working design in VCU118 (screenshot of block diagram attached below), where I can read and write the BRAM content from Jetson AGX Xavier. After transferring the exact same design to VCU128, I'm unable to detect the PCI device from jetson via lspci command.
Jetson and the FPGA are connected via PCIe.
The driver we are using can be found here https://github.com/NVIDIA/jetson-rdma-picoevb
Is there any configuration to VCU128 that I should perform before loading the bitstream?
Thanks!
