mm_uzair
Reading writing/reading PCIe Bars
I want to read/write the PCIe BARs using some logic (i mean some verilog/vhdl). Can any body help me with some related document/ application note or some sample code.
I am using virtex-5 lx50t device, ISE 11.4. I have generated the PCIe core using corgen but don't know how to proceed further.
Any type of help would be highly appreciated.
OZ
luisb
When you generate the core in Coregen there's a PIO example design provided as well.
There's also a testbench provided with the core that allows you to test out the functionality of the core.
There's a test called "pio_writeReadBack_test0" that will write to all the BARs of the core and reads the values back.
You can read about this in the User Guide and the  Getting Started Guide:
http://www.xilinx.com/support/documentation/ip_documentation/pcie_blk_plus_gsg343.pdf
http://www.xilinx.com/support/documentation/ip_documentation/pcie_blk_plus_ug341.pdf
kbandekar
I am using the sp605 board.
I want to integrate the pcie core.
I am following the simulation instructions provided by Xilinx but my simulation seems weird.
In the test environment I also do not have pio_writeReadBack_test0.
In simulation while debugging I am not able to get proper clocks i.e. trn_clk for tx data through the user logic.
My simulations I am running through is Modelsim.
Any feedback would be appreciated.
I would also like to know on the best practices to integrate the core / use the available core effectively with a custom design.
cheers,
Kunal
deepeshm
When you run the simuation script provided for modelsim, does it run?
Do you see any activity in the waveform window?
luisb
Can you also let us know what version of the core you're using?  I don't believe all of the versions of the core have the pio_writeReadBack_test0.  Only the latest version has it.
