09-27-2018 07:22 AM
Hi all
Where can I read instructions regarding how to accept the irq coming from the Xilinx FPGA (as INTA through PCIe) ? as it is coming as "assert" and "dessert" messages and not as a physical line like most of the other devices.
The operating system is UBUNTU and the number of interrupts of our FPGA device are not inclining at : /proc/interrupts .
our device is xc7vx690tffg1926-1 and we are using the "AXI Bridge for PCI Express Gen3" at the PCIe interface.
Thank you
10-02-2018 11:30 PM
If you are looking for a debugging guide, here is it;
AR#58495 ( https://www.xilinx.com/support/answers/58495.html )
10-02-2018 11:45 PM
Thank you but I'm familiar with this document
I'm looking for more of a step guide of how to 'catch' the PCIe INTA irq on UBUNTU.
Our software guys can't see the irq on our Root Complex, maybe because it is arriving as a message and not a physical irq line
10-10-2018 04:11 PM
10-10-2018 05:33 PM
Is this problem occurring with the combination of the Add-in card on which the FPGA is mounted and the Linux PC?
If so, can you implement and test the Xilinx example design and related drivers?
AR#61444 (https://www.xilinx.com/support/answers/65444.html) describes the driver of DMA and how to use it. The DMA sends an interrupt signal at the end of the transfer. With PCIe IP, there is no special setting if you disable MSI when using Legacy interrupt.
I programmed XDMA on Xilinx evaluation board VC 709 and confirmed the reception of the interrupt just by inserting it into the linux machine incorporating the driver of AR # 61444 and ran it:
CPU0 CPU1 CPU2 CPU3 CPU4 CPU5 CPU6 CPU7
0: 58 0 0 0 0 0 0 0 IO-APIC-edge timer
1: 3 0 0 0 0 0 0 0 IO-APIC-edge i8042
5: 0 0 0 0 0 0 0 0 IO-APIC-edge parport0
8: 1 0 0 0 0 0 0 0 IO-APIC-edge rtc0
9: 0 0 0 0 0 0 0 0 IO-APIC-fasteoi acpi
12: 4 0 0 0 0 0 0 0 IO-APIC-edge i8042
16: 491 0 0 0 0 0 0 0 IO-APIC 16-fasteoi i801_smbus, xdma
If possible, capture the cfg_interrupt_int and cfg_interrupt_sent signals with ila and check if the interrupt is sent from the FPGA. Also check in the command register that interrupt is not disabled.
