scollinson
Receiving constant Broadcast from Root Complex MsgD TLP's with ChipScope
I have just inserted ChipScope into my XAPP1052 design and am capturing a large number of MsgD broadcast packets with the default trigger and capture settings. Below is an example of one of the TLPs:
7300 0001 0000 007f
0000 8086 0000 0080
b400 0000 075c 06bd
Is this normal? Do I need to add another match option to only capture MWr and MRd TLPs or is there some error in my design that could be causing this?
scollinson
After further reading I've realised that these are Vendor_Defined Type 1 TLPs which are meant to be silently discarded if not implemented. Still, what is the reason for so many of these? I am going to set up another match option to ignore these packets.
scollinson
