07-26-2012 06:02 AM
When I start QEMU with a Linux kernel that compiled by myself ,It stopped at the Calibrating delay loop ...
root@ubuntu:/opt/zynq_linux# ./arm-softmmu/qemu-system-arm -M xilinx-zynq-a9 -m 1024 -serial null -serial mon:stdio -kern-dtb /opt/zynq_linux/xilinx_zynq.dtb -kernel /opt/zynq_linux/zImage -initrd /opt/zynq_linux/filesystem/ramdisk.img -nographic
ram size=40000000
error reading QSPI block device
error no mtd drive for nand flash
a0mpcore_priv: smp_priv_base f8f00000
error no sd drive for sdhci controller (0)
error no sd drive for sdhci controller (1)
Number of configured NICs 0x1
ram_size 40000000, board_id d32, loader_start 0
Uncompressing Linux... done, booting the kernel.
Booting Linux on physical CPU 0
Linux version 3.3.0-14.2-build1-01464-ged63a4d (root@Embedded) (gcc version 4.6.1 (Sourcery CodeBench Lite 2011.09-50) ) #1 SMP PREEMPT Fri Jul 20 13:40:04 CST 2012
CPU: ARMv7 Processor [410fc090] revision 0 (ARMv7), cr=10c5387d
Machine: Xilinx Zynq Platform, model: Xilinx Zynq EP107
bootconsole [earlycon0] enabled
Memory policy: ECC disabled, Data cache writealloc
PERCPU: Embedded 7 pages/cpu @c06bd000 s5696 r8192 d14784 u32768
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 60864
Kernel command line: console=ttyPS0,115200 root=/dev/ram rw initrd=0x800000,8M earlyprintk ip=:::::eth0:dhcp
PID hash table entries: 1024 (order: 0, 4096 bytes)
Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
Memory: 240MB = 240MB total
Memory: 230408k/230408k available, 31736k reserved, 0K highmem
Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
vmalloc : 0xd0800000 - 0xff000000 ( 744 MB)
lowmem : 0xc0000000 - 0xd0000000 ( 256 MB)
pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
.text : 0xc0008000 - 0xc0409c4c (4104 kB)
.init : 0xc040a000 - 0xc042e640 ( 146 kB)
.data : 0xc0430000 - 0xc045dba0 ( 183 kB)
.bss : 0xc045dbc4 - 0xc0477e1c ( 105 kB)
Verbose stalled-CPUs detection is disabled.
NR_IRQS:128
Xilinx, no compatible timer found, using default
xlnx,ps7-ttc-1.00.a #0 at 0xd0800000, irq=43
Error, no clock-frequency specified for timer
Calibrating delay loop...
Excuse me, what reason is this?Thank you.
08-09-2012 05:28 PM
--Bump--
I have the same problem. Still present in the latest Git update of Tue, 31 Jul 2012 00:13:11 +0000.
Anyone out there actually using the QEMU version?
Other than changing the kernel out, I'm using the stock dts/dtb and root file system that comes with the QEMU tarball available here:
http://wiki.xilinx.com/zynq-qemu#toc1
Kernel compilation is done via the instructions here: http://wiki.xilinx.com/zynq-linux
git
make ARCH=arm xilinx_zynq_defconfig
make ARCH=arm zImage
copy the arch/boot/zImage file to the QEMU kernel folder.
This same process produces a kernel that works fine on a 702 board.
08-09-2012 05:30 PM
Note the difference between the 702 board output and the QEMU output:
QEMU output:
NR_IRQS:128
702 board output:
NR_IRQS:128
xlnx,ps7-ttc-1.00.a #0 at 0xf0000000, irq=43
08-10-2012 04:08 PM
You need to change xilinx-zynq.dts and recompile it. zynq-ep107.dts works, though you need to enable another serial.
Archie
12-14-2012 07:31 AM
Did you guys find any solution to the problem ?
even my qemu stops at calibrating delay loops...
I am workin on Ubuntu 12.0.4 32-bit OS.
