araquirit
Sending an MSI over PCIe from axi_pcie
I'm based on the AR43371 design (http://www.xilinx.com/support/answers/43371.htm) and I would like to add the possibility to send an MSI over the PCIe to the Host CPU (not the microblaze), but I don't understand how to achieve that goal.
In fact, I would like to drive the axi_cdma_0 and axi_cdma_1 from the Host CPU (map their registers inside PCI BARs) and receive MSI 0 when axi_cdma_0 is done and MSI 1 when axi_cdma_1 is done (for example).
Inside the documentation (ds820_axi_pcie.pdf), I read that I can send an MSI with the INTX_MSI_Request signal, but how can I select the associated message number itself?
Thanks in advance.
Best regards.
araquirit
I think this is a limitation of the axi_pcie compared with the native pcie block: only one vector, no multiple vectors.
Could anyone confirm this assertion?
Also, could anyone point out what are the other limitations of the axi_pcie compared with the native pcie block?
In terms of achievable bandwidth?
In terms of other functionalities?
Best regards.
deepeshm
Yes axi_pcie only supports one vector.
There isn't any document as such that compares between the two cores but you could take a look at the data sheet of the cores and compare the provided list of features.
DMS
araquirit
Thanks for your answer.
I was asking if anyone knows about other limitations because the mono-vector limitation is not written inside the lastest axi_pcie product specification.
Best regards.
salahgamal
i have the same Question about how to send axi_DMA  inerrupt througth axi_pci without the use of microblaze processor
how can i start such this issue?
araquirit
I think the best method is to create an axi_intc to control your different interrupt sources and connect the Irq output port of the axi_intc to the INTX_MSI_Request input port of the axi_pcie.
Note that you can bypass the use of the axi_intc and connect your interrupt sources directly to the INTX_MSI_Request input port of the axi_pcie.
For the axi_intc, I think the output must be level for INTX and edge for MSI.
Could anyone confirm?
salahgamal
thanks araquirit for your replay
stv0g
I am currently trying to do the same: using an AXI INTC to trigger MSI interrupts using the AXI PCIe endpoint bridge.
Usually AXI INTC is used with Microblaze-based systems. But it is possible to remap most of the ports to the AXI PCIe bridge.
  • Use fast interrupt method in AXI INTC
  • Connect IRQ output of AXI INTC to 'INTX_MSI_Request' of AXI PCIe bridge
  • Connect the 'interrupt_address' using a slice IP to the 'MSI_Vector_Num' input
  • Connect the 'INTX_MSI_Grant' signal to the 'processor_ack'
At the last point, I ran into a problem. 'processor_ack' expects a 2 bit vector. 'INTX_MSI_Grant' is only a single bit vector. :-(
337247537@qq.com
Hi,I have the same question as you.About axi intc IP core used by your diagram,do you successfully test this and how?
hope your response
stv0g
I solved the problem adding a wrapper around axi_intc which emulates the interrupt handshaking which is expected by the PCIe AXI bridge.
I attached my packaged IP. Have a look at the VHDL code for the handshaking.
Please leave a Kudo if it works for you :-)
337247537@qq.com
Thanks for you response.I noticed your VHDL handskake code require must be MSI interrupt.But in my application,
I used legacy interrupt.I also used signal INTX_MSI_Grant output form axi bridge IP core as a handshake signal.
But I don't know how many cycle that INTX_MSI_Requst signal should be keep assert.Do you have any idea?
arhoufiry
I was wondering if you could help me.  I am having the same issue and I implemented your solution, but I still cannot see any interrupts at the host.  I have 2 interrupts going into the INTC ip core, but the host only registers 1 MSI interrupt.
Can you provide more details on how you had the INTC and PCIE core setup?
Did you have any code running on the Microblaze to support the interrupts?
