Sharing a quad between PCIe and Aurora
I would like to have a 2-lane PCIe running on 5 Gbps, and 2-lane 64b66b Aurora running on 10 Gbps (or similar bitrate). FPGA is Kintex7 Speed grade 2, reference clock is 100 MHZ. I think I have problems sharing clock resources between 2 IPs, especially due to PCIE running with same usrclk1 and usrclk2, while Aurora has ratio 1:2. Any help is appreciated.
Srdjan
There is a section on Shared Clocking in PG054.
https://www.xilinx.com/support/documentation/ip_documentation/pcie_7x/v3_3/pg054-7series-pcie.pdf
Have you reviewed it?
Also, the following answer record might be of help.
https://www.xilinx.com/support/answers/62267.html
