patocarr
Straddled case - trn_rrem_n behavior in H2 header?
Hi folks,
  I'm having an issue decoding the documentation for the PCIE Virtex-6 core in 128-bit mode. I can't seem to find the status of the trn_rrem_n bits when receiving the 2nd header in a straddled TRL.
  Let's say I receive the following TRL, 32-bit MWr:
  -- -- H0 H1   rsof_n=0 reof_n=1 rrem_n=2'b1x
  H2 D0 -- --   rsof_n=? reof_n=0 rrem_n=2'b10
  What will be the value of trn_rsof_n in this case? The documentation doesn't seem to explain this case.
  Will H2 also count as start of frame and keep trn_rsof_n asserted one more cycle?
Thanks in advance,
-Pat
Give kudos if helpful. Accept as solution if it solves your problem.
https://tuxengineering.com/blog
jayer
If you received for instance..
Dn-1 Dn H0 H1 meaning you received the last two Dwords of a previous packet and the header for a new packet you would get:
trn_rsof_n =0
trn_reof_n =0
trn_rrem_n[1] = 1
trn_rrem_n[1] = 0
If it was a case where the previous packet only had 1 DW left such as:
Dn - H0 H1
then
trn_rsof_n =0
trn_reof_n =0
trn_rrem_n[1] = 1
trn_rrem_n[1] = 1
The example you gave of:
H2 D0 H0 H1 does not seem to make sense or I am misunderstanding what you are giving as an example. Reason is the header starts at the highest order byte of the straddled half meaning the 4 bytes of the H0 will either be in the 127:96 position or 63:31 position.
John
patocarr
Replying to myself. Looking at xapp1052, it seems that trn_rsof_n deasserts for H2 in straddled case. If the same second 128-bit word had another header, ie. H2D0H0H1, then trn_rsof_n will stay asserted.
Please confirm.
TIA,
-Pat
jayer
trn_rsof_n =0
trn_reof_n =0
trn_rrem_n[1] = 1
trn_rrem_n[1] = 0
Dn - H0 H1
then
trn_rsof_n =0
trn_reof_n =0
trn_rrem_n[1] = 1
trn_rrem_n[1] = 1
John
patocarr
Hi John,
  I confused the issue by adding another example that wasn't tied to the first case. I added it to highlight the case that trn_rsof_n will stay asserted indicating a new header is present. "Header" in this case is H0H1, not H2 in the high dword.
  In my first example:
 -- -- H0 H1   1st
 H2 D0 -- --   2nd
  Please confirm trn_rsof_n state in the 2nd 128-bit word. I believe it will be deasserted, and will assert only if another header (ie. H0H1) shows up in the same beat. Of course trn_rrem_n will be different in that case.
Thanks for the quick response,
-Pat
