mmatusov
Voyager
Voyager
Tandem Configuration is greyed out in DMA/Bridge Subsystem for PCI Express in an RFSoC design
I have a design targeting ZU28 device and I want to use the Tandem PROM method for loading PCIe, however the corresponding field in the DMA/Bridge Subsystem for PCIe is greyed out with None in it. I am using Vivado 2019.1.1. Is there a way to enable Tandem PROM in this device?
/Mikhail
deepeshm
Apologies for the delay. This is schedule to be supported in a future release of the tool. If possible, we will try to make it in the next Vivado release.
deepeshm
This is currently not supported. Please refer to https://www.xilinx.com/support/documentation/ip_documentation/xdma/v4_1/pg195-pcie-dma.pdf for device support information on PCIe Tandem/PROM.
mmatusov
Voyager
Voyager
I am sure I saw in some other document that Tandem PROM was supported in RFSoCs but since it is not, what are my options in getting PCIe ready in under 100 ms? Am I supposed to use PCIe interface in the PS portion? Would that work? Any other options?
mmatusov
Voyager
Voyager
Hi @deepeshm ,
I figured out where I saw it. Here's a screenshot from PG213, page 90:
So, it's available for the PCIe Integrated Block itself but not for the DMA/Bridge Subsystem.
Any ideas of what other options I have?
/Mikhail
deepeshm
We are checking on this. We will respond as soon as we have an update.
deepeshm
mmatusov
Voyager
Voyager
Thanks!
