vanperhieu2310
Unknown header type 7f
Hi, I'm working on Numato Aller Artix 7, and facing a problem when trying to build a simple project with IP DMA/Bridge Subsystem for PCIe like a figure below. After generated bitstream and program down to board, I use command lspci -v in Linux to display information about pci buses but it's show "Unknown header type 7f". How can I fix it?
mmcnicho
This issue typically occurs when the configuration space is not accessible.
Could you check if the link up is stable?
Matt
mmcnicho
Matt
vanperhieu2310
Hi Matt,
Thanks a lot for your help. However I'm a newbie so could you please explain more how to check link up stable?
Thanks in advance
mmcnicho
I would recommend enabling the JTAG Debugger in your design use this AR as a reference.
https://www.xilinx.com/support/answers/72471.html
Let me know if this helps.
Matt
vanperhieu2310
HI Matt,
Thanks a lot for your help. I just realized that I assigned pcie ports wrong location that made the Header Type in BAR 0 incorrect
