V7 Gen3 PCIe simulation hang in initial position
Hi all
I try simulate IP for V7 Gen3 PCI Express. My options:
1) Virtex-7 vx690t
2) Core 'Virtex-7 FPGA Gen3 Integrated Block for PCI Express' v1.7 generated in ISE14.7
3) Core parameters - endpoint, x1, gen1, ref_clk 100Mhz. All other options default
4) Simulation instrument - ModelSim SE-64 10.2c
5) Start simulation by script simulate_mti.do
Program output finished with lines:
# Running test {pio_writeReadBack_test0}......
# [ 0] : System Reset Is Asserted...
# [ 4995000] : System Reset Is De-asserted...
After this I simulating more than 1ms, but nothing else happens.
Core outputs cfg_ltssm_statecfg_phy_link_status always 0. sys_clk look well, on EP/pci_exp_rxn/rxp I see some activity.
Some ideas?
Re: V7 Gen3 PCIe simulation hang in initial position
I'm sorry, I find my error. By default core top level wrapper included in EP module without parameters transfer. It led to different PL_LINK_CAP_MAX_LINK_WIDTH value between modules, and pci_exp_rxn/rxp not connect from top module to core.
