wastie
Versal ACAP VMK180 Targeted Reference Design PCIe Platform ver 2020.2
I have a problem running this example. No video file is provided for the TRD making it impossible to test. Has anyone been able to run this example. Could some provide me with a video in yuy2 format 1920x1080?
Thanks, Roy
pvenugo
@wastie ,
Please let me know what exact issue are you encountering?
Praveen
wastie
I just need a video file to test the TRD where do I find one in YUY2 format? The TRD does NOT include a Video file.
pcie_host_app
./pcie_host_app -i file.yuy2 -d 1920x1080 -t 4 this command requires a file
@pvenugo
pvenugo
@wastie ,
Please download any file from here http://ultravideo.fi/#testsequences
Praveen
wastie
Ok I have a video. Which the app seems to transfer and process but the video in the display looks like it is not synced but i can see the image in the video.
What is the filter suppose to do?
root@xilinx-vmk180-es1-2020_2:~# pcie-testapp
[  268.141456] [drm] Pid 785 opened device
[  268.145350] [drm] Pid 785 closed device
[  268.153051] [drm] Pid 785 opened device
[  268.156906] [drm] Pid 785 closed device
[  268.160864] [drm] Pid 785 opened device
[  268.307513] [drm] get section AIE_METADATA err: -22
[  268.307538] [drm] zocl_xclbin_read_axlf 744f2859-c395-444a-a8b3-3add5565cb90 ret: 0
[  268.325762] [drm] bitstream 744f2859-c395-444a-a8b3-3add5565cb90 locked, ref=1
[  268.333465] [drm] No ERT scheduler on MPSoC, using KDS
[  268.345997] [drm] request_irq failed on CU 0 error: -22.Fall back to polling mode.
[  268.353572] [drm] scheduler config ert(0)
[  268.353574] [drm]   cus(1)
[  268.357577] [drm]   slots(16)
[  268.360276] [drm]   num_cu_masks(1)
[  268.363230] [drm]   cu_shift(16)
[  268.366710] [drm]   cu_base(0x80010000)
[  268.369929] [drm]   polling(1)
[  268.373788] [drm] bitstream 744f2859-c395-444a-a8b3-3add5565cb90 unlocked, ref=0
successfully set write transfer d[  268.381229] [drm] bitstream 744f2859-c395-444a-a8b3-3add5565cb90 locked, ref=1
one
successfully set read transfer done
[  313.066515] [drm] bitstream 744f2859-c395-444a-a8b3-3add5565cb90 unlocked, ref=0
[  313.264981] [drm] Pid 785 closed device
@pvenugo
result of the filter see file
wastie
These Videos are YUV420 and not YUV so the result I got was expected with this format.
This TRD needs to provide a video that works! NOT impressed
pvenugo
@wastie ,
We were not  distributing raw video file(s) as it need license.
Apart from that 3 sec raw video file will be ~2GB. As a workaround users can use FFmpeg player to convert a opensource compressed video to raw video formats.
We've provided the feedback on lack of sample video in TRD which should be considered.
Praveen
