tony_tse
XDMA dma_to_device failed
I am a newer to Xdma, I generated a xdma example(xc7k325t-2ffg900/Gen2X8/Axi Stream/1 H2C & 1 C2H,Vivado2020.1),and I want to verify the xdma performance. I got the latest driver in github.com,and install it in my computer(ubuntu16.04).
1.When I use run_test.sh  it worked well
2. when I try to write larger size data into device,it can not work(../tests$ sudo ./dma_to_device -d /dev/xdma0_h2c_0 -f data/datafile0_4k_bin -s 4096),it  Can not  find this command (as below,the chinese words meas it can not find this command),then I open the driver directory,find dma_to_device is under tools directory,not under tests directory.
3.then I copy data directory from tests directory to tools directory,then under tool directory, I input the command :(../tools$ sudo ./dma_to_device -d /dev/xdma0_h2c_0 -f data/datafile0_4k_bin -s 4096),it can find this command,but the the data is not be written into EP.
look forward to your reply,Thank you.
liy
https://www.xilinx.com/video/technology/dma-for-pci-express.html
In that video it is mentioned that the tests try to DMA from 0x00000000 but most example designs and maybe your custom ones have the xdma core mapped on 0x0000000080000000 (0x80000000 for 32-bit) on the AXI bus.
Thus you need to change the scripts and add this offset as the video explains in 12:15. This will make the scripts call the ./dma_to_device and ./dma_from_device with -a (offset) of 0x80000000
tony_tse
Hi,liy, Tanks for your reply,I will try it as you said and reply to you soon.
tony_tse
Hi,liy,
I have seen the video you linked,But the picture is not clear,So I still don't know how to add the offset,Can you tell me how to do in the driver or my application.Thank you
tony_tse
and I used Axi Stream,not AXI MM.
liy
please change  the resolution if it is not clear
tony_tse
Thank you. I will try it,and reply to you .
tony_tse
I have tried it,but it still failed.
1.add addroffset in dma_memory_mapped_test.sh
But I used Axi Stream Interface,not Memory-Mapped.
2.
run sudo ./dma_to_device -d /dev/xdma0_h2c_0 -f data/datafile0_4K.bin -s 4096 under tools directory,it still had a error(Unknown Error 512)
tony_tse
Hello,liy,
When I generated a xdma ip by choosing AXI MEMORY-MAPPED Interface,everything seems ok ! I can write data into PCIe EP by using dma_to_device.I can write 4KB/256KB even 1MB data(I designed a 1MB RAM in my project).Maybe the driver can not support Stream Interface well(I guess),So I decide to use AXI MEMORY-MAPPED Interface for my design.
Another Question: what's 2573.230469 meaning,throughput? what's the unit,MBPS or Mbps?
Thanks again for your help.
liy
it is MBps
if can find more in the code below
fprintf(stdout,
" -%c (--%s) size of a single transfer in bytes, default %d.\n",
long_opts[i].val, long_opts[i].name, SIZE_DEFAULT);
