yaxn
XDMA driver on Windows 10 build 2004
Hello. The XDMA driver (available in AR#65444) is not working for me. The device is detected on the PCI bus, I see Xilinx DMA vendor and ID. During installation, I tried to pre-install the self-signed certificate to the "Trusted Root Certification Authorities", also I tryed to disable verifying driver signing through
bcdedit / set testsigning on
I tried to completely reinstall the driver, deleting all previous installations and certificates, tried the debug and release version - anyway, the driver does not want to be loaded at system startup, the device is not active in the Device Manager, and sometimes Windows does BSOD at boot.
yaxn
The problem was in the hardware, where there were problems with the timing of the PCIe bus. Thanks for reply
mmcnicho
I want to check if you have tried to follow the Windows driver installation steps found in the pdf attached to AR65444?
https://www.xilinx.com/Attachment/Xilinx_Answer_65444_Windows.pdf
yaxn
