Observer mohaimen_himu
ZC706 NVMe SSD "Received Master Abort" error
Hello all,
Would anyone please suggest me about the proper way of configuring the NVMe SSD controller in bare metal application. I am trying to execute nvme admin commands by using bare metal code. But I always find "Received Master Abort" error in PCIe status register. I am using ZC706 development board and axi memory mapped to PCIe block for accessing the SSD.
I am using the following project as reference:
http://www.fpgadeveloper.com/2016/04/zynq-pci-express-root-complex-design-in-vivado.html
Re: ZC706 NVMe SSD "Received Master Abort" error
Hi @mohaimen_himu
Can you indicate what commands you are using and when you see the Received Master Abort?
A Received Master Abort is usually seen when there is a Unsupported Request. There are various conditions that can cause an Unspported Request status. Can you check that the PCIe IP RP BAR_0 is configured, if this is not configured a UR will be seen. Ensure that the read request is not targeting an unsupported address.
Please review PG054 and PG055 for more details.
Kind regards,
Gareth
