mavergoos
bridge pci to pcie
hi
I write for search help for my new project
I must change the interface of board from pci to pci espress
I use the xc6slx9 as device pci at 32bit 33mhz
I read about the xio2001 but I don't know well it
can you give me an alternative, does anyone know this chip? the xio I need configure it or it is a bridge plag and play?
thanks a lot
kotir
I see a PCI express to PCI protocol translator from PLX also.
Are you looking for a soft core to be implemented in FPGA or external chip to be placed on board ?
For configuring the XIO2001, you need to check the datasheet/UG of the corrusponding chip.
KR
mavergoos
I search the external chip
anyone know the other chip for build the bridge from pic to pcie
gszakacs
Professor
Professor
Take a look at the PEX8112 from PLX (now Avago).  This is a simple one-lane PCIe to PCI reversible bridge.  It replaces the original PEX8111.  They also have a PEX8311 PCIe to local bus bridge that combines this function with a PCI to generic bus interface.  However if you already have PCI running in your Spartan-6 it's probably better to just use the PEX8112.  This will be pretty much transparent to the software as well.
-- Gabor
