Visitor anam
choosing Integrated Block for PCI Express or AXI Memory Mapped to PCI Express for DMAs to host, using VIVADO
Hello all,
I want to develop a new project with the KC705 board (Kintex-7) to send DMA packets through PCIe to the host PC, preferlly using VIVADO.  In the IP catalogue are available the following cores:
  • 7 Series Integrated Block for PCI Express (PCIe) Gen 2
  • AXI Memory Mapped to PCI Express
Since it is not possible for me buying the DMA solutions from IP partners, I would like to have your opinion because I'm a litle lost.
In a previous project with a Virtex 4 I developed a DMA engine for the PCIe logic core using the ISE tool. I never used the EDK neither microblaze. So what do you advise to me:
option 1 - adapt my old DMA engine to use it with the 7 Series Integrated Block,
option 2 -  use the AXI Memory Mapped to PCI Express, with CDMA core (I suppose).  It's beeing dificult for me understanding wich cores should I use to send DMA packets using the AXI PCI Express option.
Thank you a lot,
Ana
Teacher muzaffer
Re: choosing Integrated Block for PCI Express or AXI Memory Mapped to PCI Express for DMAs to host, using VIVADO
My take would be the first choice option. You have a working DMA solution and probably all the rest of the support structure which goes with it. If you switch to different DMA engine, you probably have to change other code too. It seems that just changing the pcie provider and adapting the bottom of your stack to the this new pcie provider is a simpler solution.
Teacher muzaffer
Visitor anam
Tank you for your reply. Now I feel more confident to choose a way.
Kind regards,
Ana
