armando
create new project for xapp1052 *.v files for htg fx100t board
Hello
I want to work with Bas Master DMA  Design (xapp1052) in a HTG fx100t board but I dont want work with PERL script
and want to create a new project in ISE 13.1 and generate *.bit file and *.mcs file load it to the FPGA and install driver and view performance of BMD .
but I dont have any document to create this project.
please help me for this.
thanks.
armando.
luisb
All you have to do is add all the RTL that is referenced in the following file:
dma_performance_demo\fpga\implement\xst\xilinx_pci_exp_blk_plus_inc.xst
Open this file in a text editor and you'll see all the files you need to add into your new Project Navigator Project.  Then you need to find a UCF that was generated with the core and that should work.  You may want to reference the UCFs that are located in the following directory as well:
dma_performance_demo\fpga\implement\ucf
Hope this helps.
armando
Hello Iuisb,
Thank you for your good help,
armando.
