omkarg
magic_stopped C2H channel 0 status bit is set
I am using the product for which following is the product guide - PG195 (v4.1) June 20, 2019 DMA/Bridge Subsystem for PCIe v4.1
I am doing Endpoint to Root Complex memory transaction. For the same I have defined the descriptors and enabled the descriptor mode for C2H transfer.
I have programmed the descriptor as per the details provided in the above mentioned PG. Yet I see 'magic_stopped' bit of the C2H channel 0 status register is set and I also have desc_error[4:0] of the same register as 0x1 which means "Unsupported request" as per the PG.
Please suggest a solution for the same
Omkar
liy
would you please check the magic bit in the descriptor?
What is the value? This should be the one suggested in the PG
omkarg
The PG suggests 16'had4b for Magic[15:0] and I have programmed the Descriptor with the same value at the same bit locations.
