wqq19870228
pcie dma driver ahout pcie endpoint in ps
i use pcie ip for endpoint in zynqmp's ps,i want to know that does it  exist dma driver which work on linux system to communicate with pcie endpoint in zynqmp's ps
borisq
hi @wqq19870228
does this help?
https://www.xilinx.com/support/answers/72076.html
Boris
mike.mandeville
This link appears to be missing or broken.
garethc
Hi @mike.mandeville
Can you create a new Forum post and I will assist you and get you the document from the AR:72076 with some details.
Gareth
If starting with Versal take a look at our Versal Design Process Hub and our
Versal Blogs
mike.mandeville
done
