pcie endpoint block plus 1v9 is not work base on p55 chipset ( intel i7 850 cpu)
 i develop dma in p45 chipset(quad cpu).it work good. however  recently i find that  in p55 chipset environment,it only pio . is core 1v9 is inCompatible  p55chipset?
  and i want my pcie card commute direct with Graphics card (point to point---fpga to gpu).is there a solution?
  thank you!!!
Hi seanlj,
I hope, that every new chipset is compatible with traditional memory transactions :-) So you need to use standard memory write/read TLPs (not IO TLPs). And for direct communication from FPGA to other peripherial card (GPU) you need to use correct TLP addressing based on PCI ID identification.
Paul
Research Assistant at Brno University of Technology | CEO at RehiveTech spin-off company
